Known Issues
Download not working
Section titled “Download not working”If you run WinUtil and get an error like:
< : The term '<' is not recognized as the name of a cmdlet, function, script file, or operable program.
try using a VPN and if that doesn’t work than report the issue to https://github.com/ChrisTitusTech/winutil/issues
Script Won’t Run
Section titled “Script Won’t Run”If you run WinUtil and get the error:
"WinUtil is unable to run on your system. PowerShell execution is restricted by security policies"
this means that your PowerShell session is in Constrained Language Mode, which prevents WinUtil from running.
Ultimate Performance Plan Not Working
Section titled “Ultimate Performance Plan Not Working”The Ultimate Performance power plan may not work on some laptops that do not fully support this power plan.
In these cases, the power plan may fail to apply, This is expected behavior on unsupported hardware.
Revert start menu tweak not working
Section titled “Revert start menu tweak not working”Revert start menu tweak stops working starting with Windows 11 update KB5089573 (released in May 2026).
In this update, Microsoft completely removed the old Start Menu code from Windows, so we aren’t able to bring it back.
Issues with PowerShell 7 or Class not registered Error
Section titled “Issues with PowerShell 7 or Class not registered Error”Installing PowerShell 7 from the Microsoft Store (MSIX package) is known to cause issues with DISM cmdlets such as Get-WindowsOptionalFeature and Enable-WindowsOptionalFeature, resulting in a Class not registered COM error.
This might also make it so running the “pre-installed app removal” will take a indefinite amount of time
Instead, install PowerShell 7 using one of the following methods:
winget (recommended):
winget install --id Microsoft.PowerShell --source winget --installer-type wixDirect MSI from GitHub Releases: Download the .msi installer from the PowerShell GitHub Releases page.
For more details see https://github.com/PowerShell/PowerShell/issues/13866
